I have my auto view set to Fit image to window, large only. Not a problem.
However, I have some comics I read regularly in XnView. It's easy enough to use the Zoom 100% button to view them. But sometimes it's rather frustrating to have to use the hand tool to get to the top of the comic, as these images are extremely long. (I know, I know - first world problems, right?)
Is there any way for XnView to automatically zoom towards the top of the image when you Zoom 100%, rather than the center? I know I could always set the scroll wheel to move up and down the image, rather than zoom, to get to the top faster... However, I use the wheel for zooming very often when viewing photos or drawings, so I'd like to avoid that option.
It's not that big of a deal, obviously. But if there is a way I for me to tweak this at all, I would really love to know.
Thanks for your time! Any help at all would be greatly appreciated!
Zoom settings on elongated pictures
- Forum Librarian
Re: Zoom settings on elongated pictures
Have you tried activating Reset X/Y in Tools » Options... » View » View?ticktoast wrote:Is there any way for XnView to automatically zoom towards the top of the image when you Zoom 100%, rather than the center?
The changelog for XnView v1.93 lists “Reset X/Y & Lock zoom” as “Fixed”, but there's still a considerable number of open bug reports for this featureXyzzy ([url=http://newsgroup.xnview.com/viewtopic.php?p=23965#p23965]Options' descriptions for 1.82[/url]) wrote:Reset X/Y - (This option is active only if 'Auto Image size' is set to 'Fit image to window width' or 'Fit image to window heightwidth'.) If checked, in windowed View, top left corner of image is aligned with top left corner of window, instead of being centered.
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=69159#p69159]'Fit width' by Numpad1 - picture not centered[/url]) wrote:Werner, please check your settings for Auto Image Size & Reset X/Y (Tools » Options... » View » View) and Lock Zoom (View menu in View mode).
- Position sur les images en plein écran
- Configurable "lock position" feature
- Always show the top of pics / Edit description in view mode
- X/Y Confusion
- Fit Window to Image and Reset X/Y incompatible?
- "Reset X/Y" setting in fullscreen
- Anyway to view an image starting from the top, not middle?
- Problem with Lock Zoom
- Reset X/Y doesn't work when "Lock Zoom" is on
- Top of image when changing...
- B1: Image position inconsistency
- Reset X/Y -> Dependency of Lock Zoom
- B6: View 'No fit' now centered
- Bugs
- Features needed
- Odd Viewer Behavior and Total Commander question
- Problem with the slider
- ctrl+/
- Option for "Mirrored Reset X/Y" (reset to the right)
- v1.98: When Reset X/Y is unchecked, image gets centered
- v1.98: "Fit image to window, small only" is just plain buggy
- Fullscreen navigation to next image
- How to lock the position of viewer while switching images
- .ini option to ResetXY to Top-Middle
