Formats
- Forum Librarian
Re: Formats
You have to install the XHTML plug-in and remove the extensions (MHT/MHTML) from the exclusion list (Tools » Options... » Browser » File List » File List » Custom files).
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=45199#p45199]HTML and similar files: suggest+bug(?) in one shot[/url]) wrote:Yes, XnView relies on MSIE for that.Drahken wrote:Indeed, I'm surprised that it even has and ONline mode. ....Unless it's actually using IE to render the html file, and thus using whatever mode IE is currently in?
