RIOT Plugin
blackdragonbird
RIOT Plugin
Post by blackdragonbird »
I'm a old user of XnView and RIOT together. The option to convert images in batch using a target image size in kilobytes is very handy to me.
But, yesterday I resolved to try the MP version of this software, but, unfortunately I can't get the RIOT plugin to work, I don't ever have a Plugin entry in the Tools menu.
Thanks in advice for any information.
Re: RIOT Plugin
currently not supported by XnViewMP, i'll add it
blackdragonbird
Re: RIOT Plugin
Thank you for the reply. :D
I will use the standalone version of RIOT in the meantime.
m.Th.
Re: RIOT Plugin
Post by m.Th. »
blackdragonbird wrote:I'm a old user of XnView and RIOT together. The option to convert images in batch using a target image size in kilobytes is very handy to me.
See in XnView MP Tools | Export... - it has a very similar GUI and supports more formats than RIOT.
m. Th.
blackdragonbird
Re: RIOT Plugin
Like I said in my first post, I use RIOT because it allow me to convert images with a target image size in kilobytes.
I like to take game screenshots, but the JPEG quality of FRAPS is stupidly bad. So, I take screens in TGA or PNG and convert them and upload in photobucket. Photobucket has a image size limit of 1MB for free users, so, I simple put my image size limit in RIOT and batch convert many files. And RIOT has very little, near zero, quality loss in the convertion. :wink:
pedalracer
Re: RIOT Plugin
Post by pedalracer »
Pierre
wow,
that is great news. Please do not forgett to notice us on this one.
I see, the export function of xnviewMP is nice but since we all tend to use the best and in this case the best algo to smush image size of png's I like to use Riot.dll with MP.
Except, you or others can tell me that there is no need to use it since the MP compression is also fine :)
My usage:
I am an online shop owner and mostly I shoot photos of our articles with my DSLR. Those very often have to be edited in Photoshop. I can save them for the web via PS....
Many times I am using MP and I 'd like to export images via Mp, too.
However, since our shop system (Prestashop) seems to compress images also I still do not know whether I need to hassle with all these :)
At least MP is great to batch compress (hopefully via Riot.dll) images of the front end of the shop (template images..).
Re: RIOT Plugin
pedalracer wrote:I see, the export function of xnviewMP is nice but since we all tend to use the best and in this case the best algo to smush image size of png's I like to use Riot.dll with MP.
FYI: You can also add a button for PngOptimizer to XnView's toolbar.
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=76242#p76242]Save images in indexed 8-bit PNG format[/url]) wrote:fnord: SuperPNG
SuperPNG is a free Adobe Photoshop plug-in for using PNG (“ping”) files. It is faster than Adobe's own PNG plug-in and saves considerably smaller PNGs.
nicky
Re: RIOT Plugin
Post by nicky »
Is RIOT-plugin now supported by MP?
