Select different print paper size permanently
ColorBlind123
Post by ColorBlind123 »
I mainly use the program to to small changes to pictures and print them on 10*15 photo paper.
Is there a way to change the default paper size from A4 to 10*15 paper, so that I don't have to change this every time I open the program?
Re: Select different print paper size permanently
Welcome aboard, ColorBlind123.
Rores (Technet forums » [url=https://social.technet.microsoft.com/Forums/windows/en-US/5efb60c8-e536-46bc-ae59-ef4ca8193051]Windows 8 default paper size[/url]) wrote:Try going to the Control Panel and then to Devices and Printers, select the printer and right click, under the drop down menu select Printing Preferences, select Advanced, and once in the advanced menu you will have the option to change the default paper size for that machine. Click ok and then be sure to click apply. You would have to do that for every printer.
Unfortunately, this seems to be a system-wide setting. What printer model do you use?
kimi
Post by kimi »
XnTriq wrote: Thu Oct 13, 2016 12:15 am Welcome aboard, ColorBlind123.
I have similar problem. Although my Hp Laser printer is configured to print in A4 paper size in Control Panel, XnView (just like IE) always defaulting paper size to "Letter" instead of A4 in print dialog, probably due to recognizing system locale as English (US). It is very annoying. How can I make XnView to print ALWAYS in A4 size?
Thanks a lot.
