Question to "Origin"
herb
Post by herb »
Hello Pierre,
XnViewMP version 1.00 has a tag "Origin" in: Info area --> tab properties --> images
My first thought was it is "Orientation" or similar, because for all my images "Top Left" is displayed.
Today I did a test with images that have different values for "Orientation".
BUT XnViewMP always shows "Top Left".
So my question is: what value is really displayed?
Thanks for your help in advance.
Best regards
herb
Re: Question to "Origin"
it's not always the orientation, but how the image is saved.
herb
Post by herb »
Hello Pierre, hello XnTriq,
thanks for your replies.
@Pierre:
Sorry, but I miss a scenario where this tag/value changes. Can you please give a detailed one.
My 2nd question is where is this value stored / taken from for display.
@XnTriq:
Sorry, I cannot answer your question. There are so many scenarions with orientation and I do not have the overview how XnViewMP should behave.
Best regards
herb
for example:
TIFF: it's the field orientation
BMP and other formats: often images are encoded bottom to top
xnview wrote: Mon May 09, 2022 12:31 pmfor example:
… like Truevision Targa:
Tools → Settings… → Formats → Write → TGA → Bottom-up orientation
https://en.wikipedia.org/wiki/Truevision_TGA#Header wrote:Bit 4 of the image descriptor byte indicates right-to-left pixel ordering if set. Bit 5 indicates an ordering of top-to-bottom. Otherwise, pixels are stored in bottom-to-top, left-to-right order.
Thanks for clarifying, Pierre!
herb
Post by herb »
thanks for your quick replies.
But I am still confused:
Tag Exif:Orientation is used for the current orientation of the image.
As far as I know also in case of *.tiff or also *.bmp images.
Or do I miss somethings?
How can it be used for something like "but how the image is saved" (as Pierre wrote).
Thanks in advance for giving me more details.
I also did some experiments storing *.tiff images. But origin alsways was: Top left
Can you tell me the steps in order to get another value for "origin"
Best regards
herb
Does this answer (part of) your question, herb?
Pixel grid origin = top/left:
0 │  a  b  c  d
1 │ 1a 1b 1c 1d
2 │ 2a 2b 2c 2d
3 │ 3a 3b 3c 3d
4 │ 4a 4b 4c 4d
Pixel grid origin = bottom/left:
4 │ 4a 4b 4c 4d
3 │ 3a 3b 3c 3d
2 │ 2a 2b 2c 2d
1 │ 1a 1b 1c 1d
0 │  a  b  c  d
herb
Post by herb »
Hello XnTriq,
thanks for all the links. A very good private lession for me (although I have not read everything till now).
Things become clearer and clearer.
Best regards
herb
