Settings - formats - rework Saving/Read/Write tabs
XnViewMP 1.4.0
Windows10 (22H2), display resolution 3840x2160, dpi scale 150%
Settings - formats - Saving Read Write tabs
rework Formats group to enhance UI/UX
It is better to use list/table control rather than tabs for formats' settings
A
(same as in XnView Classic)
  • Saving tab
    - no changes
  • Read Write tabs
    - change format tabs to list
B
  • Saving tab - minor changes
    - add Gear(or Wrench) icon to indicate that format has Options(settings)
  • Read Write tabs
    - move to Saving tab
C
  • Saving tab - most changes
    - add Read column - just to show supported formats and separate Read/Write logic
    - add Write column - old Saving checkboxes
    - add 'Show all graphic formats checkbox' from General > General tab
    - move 'Show most used formats on top of formats list in 'Save as..' dialog' to General > File operations
    - (optional) add Filter
  • Read Write tabs
Related
