Settings - thumbnails - overlay icon - add custom positioning
XnViewMP 1.6.2
it's only possible to enable/disable Browser's thumbnail overlay icons
A
  • add custom positioning functionality
    - Top left/center/right
    - Center left/right (vertical direction only, see DxO)
    - Bottom left/center/right
  • add functionality to change icons Size
    - in %, easier, but quality will decrease due to interpolation OR
    - in pixels, and add more sizes
  • (optional) app Preset functionality
    to save/load custom layouts
B
same as A, plus
  • add Header and Footer
    this way the icons can be on a solid background and not block the image
Example
  • Capture One, ACDSee, DxO Photolab
  • Lightroom
  • darktable
  • FastStone
  • ImageGlass main window layout
Related
cicciobello
Re: Settings - thumbnail - overlay icon - add custom positioning
Post by cicciobello »
Y-E-S-S-S! I would like it very much.
The idea of ​​the spacing between the icons and above all their size is interesting.
The same options would be needed for full screen too!
I support this request.
added Suggestion B, C
cicciobello
"B" is a good idea, but with customizable background color.
I don't like the vertical "C" icons, but that depends on personal preference, monitor size, etc.
