Settings - thumbnails - appearance - add shadow parameters
XnViewMP 1.9.8
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
thumbnails shadow is the same from all 4 sides, which makes thumbnails blurry
  • add parameters to alter thumbnail shadow
    eg
    - color
    - opacity
    - size
    - angle
    - distance
    - blur
  • fix dpi scaling that stretches shadow gradient
    which look unpleasant (see example below)
Example
  • XnViewMP vs Windows File Explorer
Related
