I've changed a cmd_useToolbar from the default to a sequence of two keys: A, A
This works before I restart the app, but after the restart, the old shortcut remains, and the menu doesn't show the new one. Although the default.keys file still contains this shortcut. It seems as though there is something wrong with parsing this format of key sequence and it's simply discarded?
1.9.2 64bit Windows
Shortcut sequence can't be loaded
Re: Shortcut sequence can't be loaded
however, its better to rework this functionality from sequential to multiple shortcuts
https://newsgroup.xnview.com/viewtopic.php?t=48151
esv
Thanks for the tip! Such a pity as that's such an awesome ergonomic feature
