1.9.4 - shortcuts - keys - label localization
XnViewMP 1.9.4
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Shortcuts - keys
localized labels:
- are leaking into default.KEYS
- naming is not consistent
Issue A1 - shortcuts
0. portable clean app
1. switch to Italian lang
2. restart app
Home key works in Viewer
3. goto Settings
- open Shortcuts
- press OK
default.KEYS file will be updated
Home key no longer works in Viewer because 'Home' is written as ⇱ in default.KEYS file
Issue A2
4. switch to English lang
5. goto Settings
- open Shortcuts
- press OK
6. press Home key in Viewer
it does not work because 'Home' is still written as ⇱ in default.KEYS file
it has not been overwritten from ⇱ back to Home
Issue B - consistency
Italian
mixes symbol (⇱) and word (Fine) for Home/End keys
the correct approach would be to use either symbols or words, rather than mixing them
Issue C
Polish
'Home' is named as 'Katalog domowy' which is wrong, should be just 'Home'
and it does not exist in weblate
ref
Keycap labels (simplified)
Language / RegionEscTabCaps LockShiftCtrlAltHomeEndPage UpPage DownEnterBackspace
US / UK EnglishEscTabCaps LockShiftCtrlAltHomeEndPgUp / Page UpPgDn / Page DownEnterBackspace
GermanyEscTabShift Lock / Feststelltaste / Caps LockShiftStrgAltPos1EndeBild ↑Bild ↓EnterRücktaste
FranceÉchapTabVerr MajMajCtrlAltHomeEndPgUpPgDnEntréeRetour
Spain / Latin AmericaEscTabBloq MayúsMayúsCtrlAltHomeEndRe Pág / Av PágAv Pág / Re PágIntroRetroceso
ItalyEscTabBloc MaiuscMaiuscCtrlAltHomeEndPag ↑Pag ↓InvioCanc
Portugal / BrazilEscTabCaps Lock / Bloq MaiúscShiftCtrlAltHomeEndPage UpPage DownEnterBackspace
PolandEscTabCaps LockShiftCtrlAltHomeEndPgUpPgDnEnterBackspace
RussiaEscTabCaps Lock / ЗаглShiftCtrlAltHomeEndPgUpPgDnEnterBackspace
China (Simplified)EscTabCapsLock / 大小写锁定ShiftCtrlAltHomeEndPgUpPgDnEnterBackspace
JapanEsc / エスケープTabCaps / キャプスロックShiftCtrlAltHomeEndPageUpPageDownEnter / エンターBackspace / バックスペース
KoreaEscTabCaps / 캡스락ShiftCtrlAltHomeEndPage UpPage DownEnterBackspace
Symbols
  • ⇧ Shift
    https://en.wikipedia.org/wiki/Shift_key wrote:The keyboard symbol for the Shift key (which is called Level 2 Select key in the international standard series ISO/IEC 9995) is given in ISO/IEC 9995-7 as symbol 1, and in ISO 7000 “Graphical symbols for use on equipment” as a directional variant of the symbol ISO-7000-251. In Unicode 6.1, the character approximating this symbol best is U+21E7 upwards white arrow (⇧).[3] This symbol is commonly used to denote the Shift key on modern keyboards (especially on non-US layouts and on the Apple Keyboard), sometimes in combination with the word "Shift" or its translation in the local language. This symbol also is used in texts to denote the Shift key.
  • ⇱ Home
    https://en.wikipedia.org/wiki/Home_key wrote:Its standard symbol ⇱ from ISO/IEC 9995-7, i.e. U+21F1 ⇱ NORTH WEST ARROW TO CORNER, is used on some full-size keyboards instead of a possibly localized text label.
  • ⇲ End
    https://en.wikipedia.org/wiki/End_key wrote:Its standard symbol ⇲ as described in ISO/IEC 9995-7, i.e. U+21F2 ⇲ SOUTH EAST ARROW TO CORNER, is used on some full-size keyboards instead of a possibly localized text label.
Related
