XnView: MP 1.9.4 - 64-bit
OS: Windows 10 - 64-bit
XnView does not write Rating & Category metadata to JXL file (In Settings -> Metadata - All flags under column "Export" is checked)
Effect: XMP & IPTC metadata does not change
1. Select image file (JXL format).
2. Choose category or rating.
Actual behaviour (bug): XnView does not write Rating & Category metadata to JXL file
Expected behaviour: Rating & Category metadata should be written to XMP & IPTC tags.
1.9.4: Rating & category metadata not written to JXL file
drey
Re: 1.9.4: Rating & category metadata not written to JXL file
currently rating&category can't be written in file's metadata
drey
Is it the limitation of JXL format ?
No, but currently there is no lossless change of metadata for jxl, i'll add it
GeorgD
See also viewtopic.php?p=216193 and viewtopic.php?p=216192
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
