1.9.4 - Cannot delete selected video file
john_kowalsky
Post by john_kowalsky »
XnView: MP 1.9.4 - 64 bit
OS: Windows 11 64bit
Cannot delete selected video file when context menu, Delete or SHIFT+Delete keyboard combination is used. Confirmation dialog displayed, but nothing happens when user chooses 'Yes'. The same steps work for JPEG, file is deleted.
Effect: Video file is not deleted, only hidden from the browser
1. Open a mapped network drive folder with video files in Browser. (I have MP4 HEVC files from mobile phone).
2. Choose a video file.
3. Choose Delete from context menu or hit Delete or SHIFT+Delete key combination.
4. Choose 'Yes'.
Actual behaviour (bug): File is not deleted (when context menu or Delete button is used it disappers from Browser but not from disk, with SHIFT+Delete nothing happens) :bug:
Expected behaviour: File is deleted
Re: 1.9.4 - Cannot delete selected video file
do you have auto playing for video? Are you able to reproduce each time?
BigCheese
Post by BigCheese »
Confirming this issue for me with 1.9.4
It is so critical for me I had to revert to 1.9.3 (SEE EDIT)
In current and previous versions:
When Video Autoplay is on, even when no "preview" window is being displayed, the video file is played in the background.
However, at least in 1.9.3, delete and move operations on videos seem to work correctly even with the autoplay feature on.
in 1.9.4:
Deleting AND Moving video files don't work correctly.
The problem affects not only currently selected/previewing video, but ALL VIDEO FILES IN A SELECTION.
When a delete operation is done on a selection of videos, NO ERROR is displayed and the user is given a false sense the operation was completed successfully. Videos are "removed from view" for a minute, but on refresh the video files show up again, and were never in fact removed.
When a move is made, an error is displayed that it could not remove the original source.
I think the behavior was consistent and it was happening to me pretty much every time. It made program unreliable for me to use.
I did not test the behavior in 1.9.4 with auto play videos setting off
Edit:
I decided to do more testing.
One thing to note: I use the zip version and extract/overwrite files when changing versions.
I do have most my files on a TrueCrypt volume, but it is mounted as a regular NTFS drive and not a network drive. I don't believe this is relevant, because:
While I was back on 1.9.3 I just randomly decided to turn off auto play videos
I re-downloaded & extracted 1.9.4 to test some specifics, the auto play was still off since my config carried over.
Results: Videos were being moved/copied successfully with no issue
I then turned back on auto play videos
Unexpectedly, videos STILL seemed to be moving & deleting properly!
Videos were ALSO NO LONGER being "played" in the background if there wasn't a preview window (for example, I could no longer hear audio from them). Great!
This seems to have completely fixed the issue for me, but I will update again if any further issues crop up!
Complete conjecture, but perhaps some config/setting was a bit wonky because of upgrading my XnView like I have been for so long over many versions? I just like to have my config and such carry over.
@john_kowalsky: Try what I did and see if it fixes it? Or alternatively with a fresh install of the program?
BigCheese
Post by BigCheese »
After further using 1.9.4, the main issue of not being able to move or delete the selected video returned, as well as hearing a "phantom" instance of the video even with no preview window visible.
I do not know which action caused the issue to return. I was able to clear the issues by restarting the program.
It seems like the program is getting to a state somehow, where it will start to open a instance of the video in the background when AutoPlay is enabled, AS WELL as an instance of the video in the preview window if that is visible.
The invisible instance of the video can be heard.
If a preview window is visible, and a video is selected, often the two "Instances" can be heard simultaneously, slightly offset, producing an "echo" effect.
Disabling AutoPlay and then re-enabling it does not fix the issue.
The issue does not happen if AutoPlay is off.
Restarting the program does seem to clear the issue, at least for a while.
Things I do which may play a part in this:
- I have two Saved Layouts I switch between regularly. Only one of them has a preview window.
- I sometimes switch which audio device is playing audio for a specific program (including for XNView) using EarTrumpet (similar to using built in windows Volume Mixer).
I was not able to reproduce the issue intentionally though.
john_kowalsky
Disabling auto-play and re-enabling fixed issue temporarily, but it returned once I updated to 1.9.5
BigCheese
Post by BigCheese »
I can confirm this remains an issue in 1.9.5!
Sometimes: clicking on a video file will play it in the background (audible) even when there is no preview window.
This additionally causes a conflict with the file still being in-use at a time the program doesn't expect and is not unlocking the file when deleting or moving it.
Behavior is inconsistent. It does not happen every time even with the same file and I have still not found a reliable pattern to reproduce. Once the behavior starts though, it becomes a problem until the program is restarted (and perhaps when auto-play setting is turned off/on again).
to reproduce
0. prerequisites
- default settings (no autoplay)
- have one or two video files in folder (eg smallest one from here)
1. open folder in Browser
2. select video file and Open it in Viewer
issue A
3. press Delete (or Shift+Delete) in Viewer, press Yes in confirmation popup
video file will be deleted, focus moved to another file, total index updated - OK
4. press Enter to return to Browser
video file still there
issue B
3. select video file in Browser and press Delete
video file will disappear - OK
4. press F5
video file will appear
issue C
3. select video file in Browser and press Shift+Delete, press Yes in confirmation popup
app will crash
related
1.9.4 - Cannot delete selected video file (current)
1.9.2: Video file moving fails
1.8.0: After enabling video preview, the video cannot be moved (in todo)
problem moving files
browser mode - autofocus cause video file lock
file in use?
[0.93b1] Move to not working
VictorVG
Post by VictorVG »
I try test delete selected MP4 in to browser use Shift-Del on Win7 SP1 x64 and XnView MP v1.10.4 x64 - success. For control used Far Manager b6661 and options Show hidden or system files is ON. Yes, I see delay <=10 ..15 seconds after send OS command "Delete" and event "File deleted". Only.
Xeon E5 2697v2/C602/128 GB PC3-14900L Quad Channel/GTX 1660 Ti/9 Tb HDD
Xeon E5-2697v2/C602J/128 Gb PC3-14900L Quad Channel/GTX 1660 Ti/7Tb HDD
user0 wrote: Sat Mar 14, 2026 9:53 am issue A
i can reproduce
issue B
4. press F5
issue C
app will crash
i can't here, you can always reproduce?
xnview wrote: Mon Mar 16, 2026 6:49 am
i can reproduce
it happens because video file is selected in Browser
there is no issue with deletion if video file is not selected in Browser (eg you navigated to video file from another file)
issue B
4. press F5
issue C
app will crash
yep, 100%
B
make sure video file you are trying to delete is open in Viewer tab as well
C
no crash anymore, but nothing happens - file is still there, undeleted
dernik
Post by dernik »
Hi! Having quite the same issue. App version 1.11.2
cicciobello
Post by cicciobello »
Same problem (1.11.1 Win x64).
In browser, video file delete -> file disappear, but the file is already on disk.
cicciobello wrote: Wed Jun 17, 2026 4:51 pm Same problem (1.11.1 Win x64).
auto play? each time?
cicciobello
xnview wrote: Mon Jun 22, 2026 8:10 am auto play? each time?
Autoplay is bad, autoplay never.
No, it doesn't happen all the time, but it happens often.
The first few times I didn't notice it when reorganizing the files.
I delete some videos, assign ratings, categories, etc. Everything works.
Later/the next day, I reopened the browser in the same directory and the deleted movies were still there.
As I wrote, it doesn't always happen, but to be safe I rename the files to be deleted, exit MP and delete them all together.
i've sent you a PM
