Opacity feature: Move and select remaining area no longer possible
Somebody111
Post by Somebody111 »
Previously, you could crop e.g. a screenshot of a website by selecting the desired areas from bottom to top, copying, dragging them to the desired position at the top (e.g., over an advertisement), pasting, simply dragging the entire selection further upwards, and cropping everything. Done.
Sometimes this process had to be repeated several times for the desired areas, and the already cut-out pieces had to be completely inserted each time.
This worked perfectly until now, but is no longer possible.
In one of the recent versions, a pop-up message was added asking you to confirm the size and opacity.
- If you confirm with "Apply," the selection is lost.
- If you select "Cancel," the selection is also lost.
- If you try to select the remaining area above, only the currently selected area is enlarged; selecting the remaining area above is no longer possible.
To select the entire remaining image, you now have to re-select the desired part, which isn't always easy, especially if you've already selected several parts.
This renders the function for quickly reducing the page size completely unusable.
I could not find a setting, to suppress the pop-up until version 1.9.5.
The last version where it works is version 1.9.3.
Re: Opacity feature: Move and select remaining area no longer possible
you can change in xnview.ini,
[Viewer]
pasteOldMethod=true
Somebody111
Thanks, that works. :)
Could the opacity setting perhaps be displayed in the context menu and the regular paste also?
For example:
Paste [CTRL+V]
Paste selection with opacity [another]
Frank
Ok, i'll add 'Paste in selection'
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
Somebody111
Sorry for the late reply; I didn't receive any notifications about new posts.
Thanks, it works, also with a custom shortcut [ALT+V], but the "opacity as default" solution isn't ideal in my opinion, as I rarely, if ever, use the opacity function.
A setting to enable/disable opacity, or opacity as an option, would be better.
It would be interesting to know how most users feel about this.
Tested with XnViewMP 1.9.6 and 1.9.10.
