1.9.5: Minor Bug in Viewer - Info Pane
nicholaelaw
Post by nicholaelaw »
XnView: MP 1.9.5 64 bit
OS: Windows 11 25H2 64bit
I did some custom formatting in the Info pane of View tab, encountered a minor issue regarding nested parentheses. Here's a screenshot:
Look at line 3, the focal length block has an extra right parenthesis. Here's the specific part's code:
<span style="background-color: darkgoldenrod;">{EXIF:Focal Length}mm((({EXIF:Focal Length 35mm})))</span>
What I'm trying to achieve: Display the focal length used, and if applicable, display the 35mm-equiv Focal Length in parentheses. I assume double parentheses make the field visible only if it's non-empty? So In short I want the block to look like 100mm when the 35mm-equiv FL field is empty, and 2.9mm(28) otherwise.
In fact, the code works when the 35mm-equiv FL field is non-empty, as shown here:
I think this is caused by wrongly parsing nested parentheses. Double parens got parsing priority so the code is interpreted as
((, (, {field}, )), )
where it should have been
((, (, {field}, ), ))
Just some speculations, I don't know how to solve it...
I'll attach the full code here as well, in case this is caused by something else:
{File Index}: {Filename}
<span style="background-color: darkcyan;">{EXIF:Date Taken [Y/m/d H:M:S]}</span> <span style="background-color: darkcyan;">{Width}×{Height}</span> <span style="background-color: darkcyan;">{Size}</span> <span style="background-color: darkcyan;">{File Type}</span>
<span style="background-color: darkgoldenrod;">{EXIF:Focal Length}mm((({EXIF:Focal Length 35mm})))</span> <span style="background-color: darkgoldenrod;">f/{EXIF:F-Number}</span> <span style="background-color: darkgoldenrod;">{EXIF:Exposure Time}s</span> <span style="background-color: darkgoldenrod;">ISO{EXIF:ISO Value}</span> <span style="background-color: darkgoldenrod;">{EXIF:Exposure Bias}eV</span>
<span style="background-color: darkslateblue;">{EXIF:Metering Mode}</span> <span style="background-color: darkslateblue;">{EXIF:Exposure Program}</span>
<span style="background-color: darkslategrey;">{EXIF:Model}</span> <span style="background-color: darkslategrey;">{EXIF:Lens Model}</span>
{Zoom}%
(({Tag status})) (({Rating})) (({Color label}))
Re: 1.9.5: Minor Bug in Viewer - Info Pane
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
