Files get copied instead of moved when thumbnails are moved to the end of the last file
harkonen
Post by harkonen »
XnView: MP 1.9.5 - 64 bit
OS: Windows 11
<XnView creating copy of images when moving images to the end of the list in thumbnail and file name view>
Effect: <Thumbnails get copied when moving thumbnails to the end of the last file>
1. <change view as thumbnail and filenames>
2. <move an image and place it before the last the image in the list; no copy is created>
3. <move an image and after the last the image in the list; a copy of the image is created>
Actual behavior (bug): <a copy of the file is created> :bug:
Expected behavior: <Thumbnail/file should be moved to the end, and no copy is created>
Re: Files get copied instead of moved when thumbnails are moved to the end of the last file
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
