Remove new unnecessary confirmations for copy and paste
KPAH
Post by KPAH »
Pierre, dear old friend, please do not become another Apple/Microsoft.
In the recent versions you changed the crop/copypaste feature requiring confirmation (apply) for not apparent reason, which is now thankfully changed back to what it was.
However, the same completely pointless confirmations has been added to select and then paste. Now, when you select and copy a portion of the image, and then paste, you need to actually apply the paste. Which makes it A PAIN to multi-paste the same element (like a stamp) or if you want to crop with the same selection (or expanding the same selection) after you paste.
Please revert it for how it was for the past 20 years.
Re: Remove new unnecessary confirmations for copy and paste
KPAH wrote: Thu Dec 25, 2025 6:22 pm In the recent versions you changed the crop feature requiring confirmation (apply) for not apparent reason, which is not thankfully changed back to what it was.
there have been no changes to crop confirmation since 1.5.0
KPAH wrote: Thu Dec 25, 2025 6:22 pm Now, when you select and copy a portion of the image, and then paste, you need to actually apply the paste. Which makes it A PAIN to multi-paste the same element (like a stamp) or if you want to crop with the same selection (or expanding the same selection) after you paste.
you can
  • use 'Paste in selection' command
  • click outside of pasted selection to apply it
  • press Ctrl+V twice and then Esc
  • revert to old copy/paste functionality
    add pasteOldMethod=true to [Viewer] section in xnview.ini
KPAH
Post by KPAH »
I meant this viewtopic.php?t=49665
that worked, thank you.
could we have an option in the gui settings? otherwise i'm afraid this will be deprecated at some point in the future
