Settings - presets - rework
XnViewMP 1.9.10
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Settings - presets
presets functionality is not consistent throughout the app
  • unify UI
    - add Presets dropdown in the top-right corner
    - remove Defaults, Save, Load buttons
  • unify storage
    - remove default.key, default.bar files
    - use single file for all presets to simplify management/versioning (in .ini/.json, do not use .xml)
    • Settings
      - Toolbar, Context menu, Shortcuts, Metadata
      - Info, Tooltip
Example
  • Directory Opus
Related
