Bad Shortcut naming for some Command names "cmd_rating"
openfred
Post by openfred »
In French version at least, some shortcut action names are incorrect in the View settings.
Please see the screenshot attached.
In Settings / Interface / Shortcuts it's possible to filter for example commands "cmd_rating"
In the Explorer view, the names are coherent ("Action" and "Action (Go to next image)" are using the same word)
But in the Vue Shortcut settings :
cmd_rating0m should be : Pas de note (aller à l'image suivante)
cmd_rating2m should be : Raisonnable (aller à l'image suivante)
cmd_rating3m should be : Correct (aller à l'image suivante)
I choose the correct name regarding the wording used in the Explorer setting, to be coherent.
Re: Bad Shortcut naming for some Command names "cmd_rating"
I fixed similar wording inconsistencies for French and several other languages
I thought these cases were covered by @default values used in ##label##
related
Metadata - labels - add presets, add rating
