XnView MP 1.11.5 64-bit 29.2.2026
Windows 11 64-bit
After installing the latest version 1.11.5, an old bug turned up again and I cannot get rid of it.
When I right-click to move to the next picture, it does not work, and a menu turns up on the image instead (screenshot)
This does not happen with left-click (the previous picture). I made a workaround and use the space bar instead, but I am so used to right-clicking that it has become an automatic reflex.
My mouse settings are in a screenshot as well.
I also wanted to attach my ini files but the attachment tool refused both .ini and .txt as invalid file extensions.
Unwanted menu with right-click when scrolling images
Orfanomondo
Orfano Mondo
Orfanomondo
Re: Unwanted menu with right-click when scrolling images
Thank you for your prompt reply.
Me a simple man, me no understand.
None of the suggestions/solutions in the given link works. My mouse settings/choices are not like the ones described in those images and answers. I cannot make those choices.
I would very much apprecciate a short and simple reply, just telling me which way I should configure my mouse settings from the available choices I have. I therefore re-attach the screenshot.
The only way I have found is to set both right and left buttons to do nothing and use the wheel for previous/next file, but I definitely need the wheel for zooming in and out.
What do others do? What is the quickest or handiest way to move between pictures?
This has worked since I first started with XnView in 2008. It still works in classic XnView. How can this be so difficult?
Who wants a menu when they want to move to the next picture, especially since that menu does not have the choice: next picture.
All "improvements" or changes do not make life easier for the user. Sometimes they make life more "combilicating" as my Egyptian friends would say.
Orfano Mondo
it will be fixed in the next version
Orfanomondo
Thank you in advance.
For the more adventurous, the problem disappeared when I tried the beta QT6 version as suggested to me in another post of mine about a different problem.
With the regular left button set to: Previous image and the right button to: Next image, the intrusive context menu disappeared.
Orfano Mondo
