XnView MP 1.11.5 64-bit 29.2.2026
Windows 11 64-bit
I don't know which category this problem of mine belongs to, i.e., where to post it.
For the longest time, I have had a problem with mp4 files. After I close a video, I cannot delete the file from the folder where it is. When I delete it, it first disappears, but then returns immediately. At the same time, the sound keeps playing although the file is no longer open. It is as if it were stuck on a loop somewhere invisible. I also cannot delete the file from the File Explorer because it says the file is still open in XnView, even though I have closed it.
The only workaround is to close MP completely, then delete the file in File Explorer, and then open MP again, but this is really irritating when going through many files and wanting to delete a file here and another one there.
I am aware that in my Misc. settings, I have ticked both Auto-play video and Loop video playing (screenshot). However, unticking the boxes does not change anything, not after closing and restarting MP or even after restarting my computer. The problem remains.
1.11.5 Cannot delete mp4 files
Orfanomondo
Orfano Mondo
Orfanomondo
Re: 1.11.5 Cannot delete mp4 files
Thank you, user0, Xnthusiast.
I read through the whole chain of messages. Was there an answer, explanation, solution or a fix to the problem? Yes, it is the same subject. I mentioned that I can toggle the auto-play videos and replay videos on and off, without any result. I still cannot delete videos, singly or in a selection; they always return. I did not even mention that there is more. I cannot move video files between folders either. Either the file does not move, or it says that there already is a file with the same name, do you want to overwrite it? Yes, but it says not possible, cancel.
Again, I would like to know how others delete their mp4 files and whether anyone has found a solution.
Orfano Mondo
noOrfanomondo wrote: Wed Jul 15, 2026 5:46 pm Was there an answer, explanation, solution or a fix to the problem?
but you can try QT6 version, it uses different video handling
Orfanomondo
Hurray, it seems to work! Thank you for your suggestion. I hope this becomes generally available soon.
However, it only works if I turn both Autoplay videos and Loop videos off, and most importantly, the file must not be open in the browser. I hope these will get fixed as well.
Another funny thing, all the video thumbnails are upside down in the Browser window. But this does not affect the preview picture or the actual video in the Viewer. Both are ok. I hope you will notice this.
Miraculously, this also fixed my other problem, the flaming menu disappeared when I right-clicked for the next picture!!!
I hope this too will soon become generally available.
Thank you for your efforts to improve, keep up the good work.
Orfano Mondo
Orfanomondo
To whom it may concern
I have experimented further with the Qt6 version and noticed that I can delete mp4 files safely without them popping up anymore, even if both the Auto-play videos and Loop videos boxes are ticked in the Settings Misc. section. It is only necessary to close the file in the Browser.
Also, the context menu no longer appears on left- or right-click when moving to the previous/next image. However, I had to uninstall MP 1.11.5 for both of these to happen and for QT6 to work properly. They kept interfering with each other. You cannot use both versions simultaneously on your computer without various commands going haywire.
Orfano Mondo
