I'm wondering, is there a possibility to correct white by point an eyedropper to a white spot on the image?
Like the functionality which is present in Photoshop.
So far I've found only "Auto levels" functionality (Ctrl-Alt-L).
It would be nice to have this functionality for CR2 format (RAW for Canon), but for JPEG this functionality is also appreciated.
Is there white balance correction using eyedropper?
Neighbour
MikeTheWatchGuy
Re: Is there white balance correction using eyedropper?
I came to this forum to ask that very question. Or just a "white balance" in general was one I wanted to ask about.
I'm using a scripting program called Able Batch Conversion. I bought it years ago because it was one of the few, if not the only one at the time, that would do "deskewing". It has two different white balances. I use only one of the two.
What I need the white balance for is that I scan a lot of old books and reference materials. These end up having a gray background when converted to gray. So the document has a gray appearance in general. With Able a White Balance typically makes it a white page.
I'm going to make a separate post about whitening pages that will perhaps help you with your use of White Balance. I've got my fingers crossed that I get more responses than you have in the past 7 months.
- Forum Librarian
There is no eyedropper for white balance correction. This has been requested and discussed several times in the past, though.
- Threshold slider whec converting to black and White
- Binary(b/w), edge detect, outlines?
- Peut-on configurer la convertion en .GIF binaire?
- Convert Multiple Jpeg to Tiff (CCITT Group 4 BW)
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=70748#p70748]Modify Automatic contrast command and Levels tool[/url]) wrote:
- Image correction
- which optimal settings for a captured page?
- Harder "Autolevels" (like Photoshop)
- Autolevels: What do you use? XNView or Photoshop?
- "Automatic levels" adjustment wrongly implemented
- Autolevels
- Equilibre des blancs dans Xnview ?
- Automatic whitebalance
- display values when auto correcting
- AutoColor function in XnView/NConvert?
