1.7.2 - archive - issues with temp files
XnViewMP 1.7.2
Browser/Viewer - archive
to reproduce:
0. prerequisites
  • extract files from attached archive into new folder
    test_files_archive.zip
  • open this new folder in Browser
  • open windows temp folder in file explorer
Issue A1
1. double click on CBR or CBZ file (eg 1_cbr_green_zip.cbz) to enter inside
2. select any file inside and press F3 or F4
- temp subfolder will be created in win temp folder
- 0 size file will be created inside
- external app will not be able to load 0 size file, showing error message
expected behavior
create files with correct size
also unify path for temp files creation (w/ or w/o subfolder), eg maybe create temp subfolder per session
Issue A2
2. double click on image inside to open it in Viewer
3. press F3 or F4
nothing happens
expected behavior
open image in associated viewer/editor (the same way a new unsaved image behaves)
Issue A3
1. double click on 6_test_arch.zip to enter inside
no file is selected, but xnview_temp_GwUuVx.mp3 will be created in win temp folder
2. select test_arch.mp3 in Browser
Info panel > Properties > Image will show: Note to developer : you must create an object before
3. double click on open test_arch.mp3 to open
File can't be loaded! error will appear
4. drag&drop .mp3 from Browser into external video/audio player (vlc, potplyer, etc)
new temp subfolder will be created with 0 size file (issue A1)
error will appear
vlc wrote:Your input can't be opened:
VLC is unable to open the MRL 'file:///C:/temp/XnViewMP-GtKXnb/test_arch.mp3'. Check the log for details.
Issue B
1. select any .CBZ or .CBR file
temp thumbnail files (xnview_temp_hAsH.extension) will be created in win temp folder for each CBR/CBZ file:
- if ☑ Catalog - once
- if ☐ Catalog - on each folder visit
2. close Browser tab / exit app
temp files are still there and not deleted
expected behavior
all temporary files must be deleted after closing app (or Browser tab)
Note: temp subfolders are deleted correctly when closing app
Issue C
1. double click on CBZ file (eg 2_cbz_green_folder_zip.cbz) to enter inside (OR just enter into archive with single empty folder)
folder thumbnail depends:
- if ☑ Catalog - thumbnail is incorrect (it uses some previously cached image). Also, it still the same incorrect thumbnail even after deleting db files
- if ☐ Catalog - thumbnail is correct
path in database will be added as slash dot slash \.\
Related
