1.7.2 - archive - issues with opening
XnViewMP 1.7.2
Browser/Viewer - archive (CBR, CBZ)
to reproduce:
0. extract test files (renamed .zip/.rar archives [normal compression, 4Mb dictionary]) into new folder:
test_files_archive.zip
Issue A
1. open folder in Browser
2. double click on CBR or CBZ file to enter inside
3. execute 'Open in file explorer' command (in context menu) for any file inside archive
win file explorer opens Desktop instead of the actual file location
expected behavior
open archive folder and select archive (if no temp file has been created)
Issue B
entering inside is not recorded in navigation history
3. press Back button
if you have any navigation history, you will go to the previous folder
expected behavior
simply exit the archive file while remaining in the current folder
Issue C - fixed in 1.8.1
1. open PNG file via double click in win file explorer
2. scroll to other files
index changes, but no any image is visible and tab name remains the same (0_png)
however, no such issue with 5_cbr_works_OK.cbr
Issue D
1. open 5_cbr_works_OK.cbr via double click in win file explorer
file opens in Viewer, but only 1st file in archive is displayed, page controls (first/last, prev/next page) are disabled
expected behavior
page navigation should work
Issue E - fixed in 1.8.1
1. open CBR or CBZ file in Viewer
- via drag&drop into Viewer tab OR
- via double click in win file explorer
"File can't be loaded!" error message appears
(also all files open without any issues from Browser tab)
Related
Last bumped by user0 on Sun Aug 04, 2024 8:38 pm.
