JPEG Estimated Quality in Info panel 'Properties' gone? Histogram too?
FaceCrap
Post by FaceCrap »
I'm not sure if this is by design, or something on my end. But since I think the last 2 or 3 updates, I no longer have an 'Estimated Quality' in the Info panel 'Properties' for JPG's.
The panel itself seems to have issues to. There used to be a Histogram panel which is now MIA.
If I right-click on the tab area of the panel, it's still listed on the context menu as item, but when I put a checkmark in front, the histogram stays gone...
Re: JPEG Estimated Quality in Info panel 'Properties' gone? Histogram too?
FaceCrap wrote: Thu Apr 11, 2024 8:38 pm I'm not sure if this is by design, or something on my end. But since I think the last 2 or 3 updates, I no longer have an 'Estimated Quality' in the Info panel 'Properties' for JPG's.
on all jpeg?
If you try to uncheck/check?
FaceCrap
Post by FaceCrap »
xnview wrote: Fri Apr 12, 2024 6:05 am on all jpeg?
Yes!
xnview wrote: Fri Apr 12, 2024 6:05 am If you try to uncheck/check?
Makes no difference. Nothing happens when I toggle the checkmark.
Ok, Judging from your question. I'm gonna wipe it from the system and re-install.
Perhaps I left some traces behind the first time I tried.
Ok, system cleaned of all possible traces... re-installed.
Got the histogram tab back, but the panel stays empty all the time.
Estimated Quality for any and all jpg's still MIA...
FaceCrap wrote: Wed Apr 17, 2024 12:50 am Got the histogram tab back, but the panel stays empty all the time.
Please send me a jpeg sample file?
FaceCrap
Post by FaceCrap »
You're serious? You're going to tell me you don't have any jpegs available?
ok... here's one... err.... three...
No Estimated Quality
No Histogram
There are no such issues with clean 1.7.1
try to delete xnview.ini
However, some strings may be omitted if they are too low / "incorrect", eg:
  • no XY DPI
    xnview wrote: Mon Apr 15, 2024 12:11 pm right, at loading, if dpi is <= 2, it's not a good value for me
  • no Dimension (your image on the right)
I think values that "always exists" (eg Dimension, DPI) should not be omitted even if they are close to 0.
FaceCrap
Post by FaceCrap »
user0 wrote: Mon Apr 22, 2024 7:08 pm There are no such issues with clean 1.7.1
I did, and yes, both the Estimated Quality and the Histogram showed. But as soon as I started modifying the layout using the "Free" menu item, both disappeared again, not to be seen again until I delete XnView.ini again...
I give up...
if it were the only thing... but I I reported several versions back that I can't even watch MP4 files without it crashing after closing the viewer tab.
Plus the weird tab behavior in the browser when you rename files... and yes, I know it's a QT thing, but a workaround shouldn't be that difficult...
FaceCrap wrote: Sat Apr 27, 2024 3:36 amI did, and yes, both the Estimated Quality and the Histogram showed. But as soon as I started modifying the layout using the "Free" menu item, both disappeared again, not to be seen again until I delete XnView.ini again...
Please send us your xnview.ini
FaceCrap
Post by FaceCrap »
xnview wrote: Sat Apr 27, 2024 2:57 pm Please send us your xnview.ini
As requested.
Two zips, one where both EQ and Histogram are present:
XnView-Slightly-Default-Layout-Has-EQ-and-Histogram.zip
And one where they went MIA after layout change:
XnView-Desired-Layout-Lost-EQ-and-Histogram.zip
Name of the zip is indicative for the contained and literally named "XnView.ini" file with layout having/lost EQ and Histogram.
'Estimated quality' & histogram use preview
FaceCrap
Post by FaceCrap »
xnview wrote: Tue Apr 30, 2024 1:56 pm 'Estimated quality' & histogram use preview
I'll be ... Wouldn't have thought... they're back! 👍
