Windows
| Package | Architecture | SHA256 |
| ZIP | x64 | 368256535E419AD62AF8423809C7E8C685F14B326C5DF80361B80BF21EE8B72E |
| SETUP | x64 | B1CFF97C5815FC3D63B1A64845CA1ECE4D255A3A8456AC927D555A74820344F7 |
Mac
| DMG | x64 | 7A38354B88BB4D3CF8B229F6716886B8C569FFC456EC8DDE557C79E87D404489 |
Linux
| TGZ | x64 | 658CD0913C15B0C3865CB1CB47157A77430268E087AE553C61EDFEBFD4E618BD |
| DEB | x64 | ADF708C1C128BF0E135310D1186F61214BFE29238657DD5B4A701AD8A26C3A90 |
| AppImage | x64 | |
| Flatpak | x64 |
ARM
| TGZ | arm64 |
Changelog
3843: [Bug] Thumbnails label - keywords sort setting
3842: [Bug] Batch rename - Companion not renamed
3841: [New] Tree indentation setting
3840: [Bug] Batch convert - skip - not need to load source before checking - viewtopic.php?t=47336
3839: [Bug] StatusBar - viewer - swap position/selection - viewtopic.php?t=49577
3838: [Bug] Viewer - navigator - add pan on click - viewtopic.php?t=48872
3837: [Bug] Image copying fails to display - viewtopic.php?t=50002
3836: [Bug] Batch rename - \ with replace - viewtopic.php?t=49793
3835: [Bug] Windows - Save dialog - Accelerator key - viewtopic.php?t=50059
3834: [Bug] Viewer - fullscreen - autozoom issue - viewtopic.php?t=50125
3833: [Bug] Batch rename - replace - empty value - viewtopic.php?t=50112
3832: [Bug] Pixelated image when using high quality zoom - viewtopic.php?t=46686
3831: [Bug] Search - Filename field
3830: [Bug] Browser - folders - settings show desktop - viewtopic.php?t=47535
3829: [Bug] '[' and ']' no longer work as chars in search on filename - viewtopic.php?t=50085
3828: [Bug] Paletted 4-bit PNG image is displayed incorrectly when zoomed in - viewtopic.php?t=50065
3827: [Bug] Palleted image - Lanzcos zoom - transparent index not visible
3826: [Bug] Browser - thumbnails - show transparency grid - viewtopic.php?t=50061
3825: [Bug] Browser - metadata - color mode is always RGB - viewtopic.php?t=50055
3824: [Bug] EXIF:XPSubject issue - viewtopic.php?t=50060
3823: [Bug] Layout reworked - viewtopic.php?t=49941
3822: [Bug] Compare - pan - viewtopic.php?t=49727
3821: [Bug] Browser - filelist - rename - incorrect cursor position - viewtopic.php?t=45691
3820: [New] Edit - zealous crop and remove strip - viewtopic.php?t=42595
3819: [Bug] Export Dialog - show calculation time - viewtopic.php?t=4981
3818: [Bug] FTP - fix date format - viewtopic.php?t=49875
3817: [Bug] Browser - album - issues with adding objects - viewtopic.php?t=50006
3816: [Bug] Slow lossless crop - viewtopic.php?t=49971
3815: [Bug] Encoding for EXIF image description - viewtopic.php?t=49859
3814: [Bug] Custom labels don't work correctly with video files - viewtopic.php?t=50000
3813: [Bug] Browser - Empty histogram
3812: [Bug] Image compare - zoom filter - viewtopic.php?t=49826
3811: [Bug] Draw tool - pencil draw - undo - tool changes - viewtopic.php?t=49979
3810: [Bug] Smart album - saved filename is not shown - viewtopic.php?t=49983
3809: [Bug] File listing generator CSV files are invalid - viewtopic.php?t=49888
