1.11.2 - settings - catalog - thumbnail size - params ignored during autoimport
XnViewMP 1.11.2
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Settings - Catalog
to reproduce
0. prerequisites
- have test folder with 1 image file (any format, size:>150Kb, >500px)
- delete Thumbs.db and XnView.db
1. open folder in Browser
db will be created, file autoimported, thumbnail created - OK
2. go to Settings>Catalog - Database table
- check size in Size column (eg 100 KiB)
- check BLOB size in Thumbs.db>Datas table>Size field (same 100 KiB)
3. press 'Rebuild thumbnails' button
size will be reduced by almost half (eg to 50 KiB)
it looks like during initial auto-import default params (192x144, Lossless-zip) are ignored and some other params are used
no such issue when you manually import via 'Import folder...'
Related
