Windows11 (26H2), display resolution 3840x2160, dpi scale 150%
Viewer - selection
it is not possible to lock aspect ratio of free selection, which is inconvenient
- improve behavior with modifier keys
- resize
Shift - lock aspect ratio, dragging side/corner point has different effect, see Crop mode (also same as in GIMP, Ps)
Ctrl - lock aspect ratio to square (current Shift behavior)
- move
Shift - limit movement to 8 directions (✳, 45deg steps)
- resize
Related
- issues
1.8.2 - viewer - selection - issue with state indicator in Edit menu
- todo -
1.6.1 - viewer - selection - incorrect position of size indicator while zooming
- fixed -
1.8.2 - viewer - selection - swap width and height shortcut issue (1.8.3)
1.8.1 - viewer - selection - resizing when setting free aspect ratio (1.8.3)
1.7.1 - viewer - selection - issue with SHIFT (1.7.2)
1.4.4 - viewer - selection loses highlight after Spotlight (1.5.0)
1.4.4 - viewer - selection - status bar does not update after ratio change (1.4.5)
1.4.3 - viewer - wrong selection when resizing to 1x1 (1.6.0)
- suggestions
Viewer - selection - improve behavior with modifier keys (current post)
Resize - size - unify naming
Print - sizes - unify naming
Viewer - selection - size - unify naming
Viewer - selection - ratio/size - make presets global
Viewer - selection - ratio - add Fixed option
- done -
Ratio - improve naming and sorting (1.6.0)
