Settings - view - add Zoom tab, reshuffle controls
XnViewMP 1.8.2
Settings - view
lack of settings grouping, which is not convenient
General
  • Zoom
    - split Zoom settings into separate tab
    - remove 'step' from Zoom step options in combobox
    - move 'Reset X/Y (No fit)' under 'Auto zoom'
  • Background
    - group Background settings
    - add 'Canvas background color' setting (from Viewer menu Edit>Background color...)
  • Quick Slideshow
    - split into new tab (2nd level)
A
  • Background
    - group settings into Viewer and Canvas Background
B
  • tabs
    try to reorganize settings between ui appearance and something more technical
    - rename 'View' → 'Viewer'
    - rename 'Misc.' → 'Render'
  • Background
    - minor renaming
C - preferable
same as B, plus
  • general
    - move
    • Loop on the file list → View > Filter
      - rename 'Filter' tab to 'File list'
      - use two groups 'File list' and 'Filter'
    - rework - rename
    • Reset 'Auto zoom' setting with next/previous file →
      Reset custom zoom on file change OR
      Navigation resets zoom
    • Reset X/Y (No fit) →
      Reset X/Y position on file change (No fit) OR
      Navigation resets X/Y position ('No fit' only)
Example
  • acdsee
  • nomacs
Related
