Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Edit IPTC/XMP dialogs - templates
Save/Load template controls do not follow app UI
- rework Save/Load template controls to match Presets
- 'Load template v1..' button
- either remove completely OR
- just check file extension on load: .iptc - new, .ipt- old
- move loading options to Options tab
- checkbox 'Merge data'
- checkbox 'Don't load field values
Related
- issues
- todo -
1.9.8 - metadata - write hierarchical keywords ignored
- fixed -
1.7.1 - metadata - automatically apply parent category ignored (1.7.2)
- suggestions
Metadata - labels - add presets, add rating
Metadata - edit xmp - writing to unsupported format
Metadata - edit dialogs - template - rework controls (current post)
Metadata - edit dialogs - save modes
Metadata - edit dialogs - merge all into one
Metadata - clean - remove from Catalog
Metadata - clean - add support for more formats
Settings - metadata - export - enable Rating&Color by default
Settings - metadata - add auto/manual import mode switch
Settings - metadata - add high level rw options
Browser - metadata - Update catalog/file commands - clarify behavior
- done -
Settings - metadata - move Comment into Metadata group (1.11.4)
Metadata - edit xmp - update rating appearance (1.9.0)
Settings - metadata - sidecar - minor UI adjustments (1.7.0)
Metadata - unify menu group in Browser/Viewer toolbar and context menu (1.5.0)
