1.12.2 - viewer - antialiasing - settings enforcement
XnViewMP 1.12.2
Windows11 (26H2), display resolution 3840x2160, dpi scale 150%
Viewer - anti-aliasing
1. open image in viewer, zoom-in to 101% or -out to 99%
2. goto Settings>Viewer>Zoom
- change zoom-in/out to any filter, except None
- press OK
3. in Viewer tab, enable/disable AA
selected filters will be applied in both cases (zoom-in and -out) - OK
4. goto Settings>Viewer>Zoom
- change zoom-in/out to None
- press OK
5. in Viewer tab, enable/disable AA
old filter will be applied
expected
should be None for both cases
Related
