Please, don't post bugs or requests in this topic!
You can download XnView MP 1.8.4 here:
Windows x64 ZIP version SHA256: 9E83FB2EA5CA49F375029D8DFA8B7FBB9EFEB153212D8CDF1747158FF2A55C64
Windows x64 SETUP version SHA256: 7D2BF17974FE324DAD61EA59B263F9D5EA3033E08CAA38AE5E25CBEAACA23AD1
Mac x64 DMG version SHA256: CD6732583C291A5EBD7867AEF41A33F288C18A62A04FE52EEE577ECFC93E32F3
Linux x64 TGZ version SHA256: 76454D3FA41D07571C24C83879994E2CEB866FF43DD036C6B0E1C7CBBBE8CE81
Linux x64 DEB version SHA256: AD7B78A56BFD8CC0FFADA1BC014459F2B0E66006FCFAD1FE6254BAA773FF9A5F
ARM version: https://download.xnview.com/XnViewMP-linux-arm.tgz https://download.xnview.com/XnViewMP-li ... _armhf.deb
Linux x64 AppImages version: https://download.xnview.com/XnView_MP.g ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 1.8.4:
3439: [New] MDK 0.31.0
3488: [New] JPEG-li in JPEG settings - viewtopic.php?t=47206
3486: [New] darktable color label import
3483: [New] LibRAW 0.21.3
3479: [New] Categories - show orphaned category
3477: [New] LibJpegXL 0.11.1
3476: [New] LibHeif 1.19.5
3472: [New] Thumbnail - image alignment - viewtopic.php?t=47620
3470: [New] Edit XMP - merge keywords - viewtopic.php?t=48299
3467: [New] Hide set category menu - viewtopic.php?t=48205
3466: [New] Browser - thumbnail - overlay icon - add multipage video audio - viewtopic.php?t=46452
3464: [New] MacOS - jpeg2000 - internal decoder - viewtopic.php?t=47088
3462: [New] Untagged filter - viewtopic.php?t=48192
3461: [New] DPI x y placeholder - viewtopic.php?t=46343
3459: [New] About - ini link - viewtopic.php?t=48264
3454: [New] Batch convert - border - enlarge option - viewtopic.php?t=48207
3437: [New] Effect - blur more - viewtopic.php?t=48097
3491: [Bug] Browser - metadata - sidecar - setting ignored for WEBP - viewtopic.php?t=48471
3490: [Bug] Export - jpegli - keep metadatas - viewtopic.php?t=48464
3489: [Bug] Orphaned categories after root delete
3487: [Bug] Viewer automatically scrolls away if opening excluded formats - viewtopic.php?t=48379
3485: [Bug] Space at the end of folder name - viewtopic.php?t=48431
3484: [Bug] View - Auto zoom - Fit image to desktop - viewtopic.php?t=48314
3482: [Bug] DNG embedded image problem - viewtopic.php?t=48421
3481: [Bug] Thumbnail - gamma or sharpen not applied - viewtopic.php?t=48417
3480: [Bug] PSP crash - viewtopic.php?t=48410
3478: [Bug] Transfer - iptc field missing - viewtopic.php?t=48370
3475: [Bug] Custom thumbnail labels - folder name or directory as place holder on video file
3474: [Bug] 'show companion files' doesn't reset icons
3473: [Bug] ICNS - viewtopic.php?t=48330
3471: [Bug] Fit to window - reset fit - viewtopic.php?t=48315
3469: [Bug] Mouse wheel doesnt work in preview - viewtopic.php?t=47122
3468: [Bug] Tag in fullscreen - viewtopic.php?t=48191
3465: [Bug] Category icon not shown when folder is not yet in catalog
3463: [Bug] Tag status placeholder - viewtopic.php?t=48188
3460: [Bug] Batch rename - UI - viewtopic.php?t=47647
3458: [Bug] Lossless setting - viewtopic.php?t=48242
3457: [Bug] Settings - integration - windows file associations
3456: [Bug] Similar - bad preview after deleting ref - viewtopic.php?t=48163
3455: [Bug] Refresh on tagged list - viewtopic.php?t=48165
3453: [Bug] Compare - rating not shown - viewtopic.php?t=48173
3452: [Bug] Wrong Focus moving files in Fullscreen - viewtopic.php?t=48030
3451: [Bug] MacOS - AV1 video - viewtopic.php?t=48240
3450: [Bug] Edit XMP dialog - smaller height
3449: [Bug] Batch convert - remove filtered unfiltered items back - viewtopic.php?t=48201
3448: [Bug] AVIF HEIF - lossless output - viewtopic.php?t=48215
3447: [Bug] Batch convert - resize in percent - viewtopic.php?t=48200
3446: [Bug] JPEG2000 - encoding - viewtopic.php?t=48228
3445: [Bug] Sidecar files with a dot in the filename are not excluded - viewtopic.php?t=48157
3444: [Bug] Edit IPTC - tab order - viewtopic.php?t=48180
3443: [Bug] Batch convert - Greyscale - inner frame
3441: [Bug] EXIF - Sometimes Image (IFD0) fields in Camera group
3442: [Bug] JPEGXL - EXIF XMP metadatas - viewtopic.php?t=47926
3440: [Bug] Categories sorting - viewtopic.php?t=48126
3428: [Bug] GIF with unknown extension block
3438: [Bug] Next frame - viewtopic.php?t=48164
3436: [Bug] JPEG-XL with orientation exif - viewtopic.php?t=48112
3435: [Bug] File index error in info - viewtopic.php?t=48086
3434: [Bug] Draw - eyedropper - no options should be available - viewtopic.php?t=48100
3409: [Bug] Viewer - selection - swap width and height shortcut issue - viewtopic.php?t=48035
3433: [Bug] Curve effect does not apply to the selection area - viewtopic.php?t=48113
XnView MP 1.8.4
XnView MP 1.8.4
