Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Settings - catalog - maintenance
Files column counts not only files, but folder records as well
- do not count folder in Files column
eg filter out by 0 size
Related
- issues
- todo -
1.11.2 - settings - catalog - thumbnail size - params ignored during autoimport
- fixed -
1.10.5 - settings - catalog - incorrect sort order (1.11.4)
1.8.7 - settings - catalog - get thumbnail size issue (1.9.0)
1.4.4 - settings - catalog - hang when sync unmounted drives (1.6.0)
1.4.5 - settings - catalog - fix Build thumbnails dialog (1.5.0)
1.4.5 - settings - catalog - cache size control remains enabled with disabled Catalog (1.5.0)
- suggestions
Settings - metadata - add auto/manual import mode switch
Settings - metadata - add high level rw options
Browser - metadata - Update catalog/file commands - clarify behavior
Browser - add Catalog pane
Settings - catalog - do not count folders in Files column (current post)
Settings - catalog - synchronization - improve dialog
Settings - catalog - UI adjustments of Excluded folders
- done -
Settings - catalog - add maintenance tab (1.11.4)
Settings - catalog - make Directory column wider (1.11.4)
Settings - catalog - group thumbnail caching settings | move uom out of control (1.8.7)
Settings - catalog - maintenance button and dialog (1.7.0)
