Settings - catalog - indicate missing folders
XnViewMP 1.11.7
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Settings - catalog - maintenance
there is no indication when folder in db is out of sync with the file system,
eg because it has been renamed, moved, or deleted, which is inconvenient
  • add missing folder indicator (like in Lightroom, Capture One)
    - add separate Status column instead of the current approach, where ⚠️ is added in front of the path
Example
  • Lightroom, Capture One
Related
