1.12.2 - view - transparent index visible when zooming
XnViewMP 1.12.2
Windows11 (26H2), display resolution 3840x2160, dpi scale 150%
Viewer/Browser(Preview)
to reproduce
0. have 32bit and ≥8bit images with transparency in folder
test_img_transparency_index_issue.zip
1. open 32bit image in Viewer (eg 10_rgb_alpha.png)
2. uncheck 'Use alpha channel'
3. navigate to ≥8bit image
transparent index is transparent - OK
4. zoom-in
transparent index will be visible
5. uncheck/check 'Use transparent index' command
nothing happens, transparent index remains visible
  • maybe combine 'Use alpha channel' and 'Use transparent index' into single 'Use transparency' command
    as they do the same thing, the only difference is image color depth and there is always only one image per viewport
Related
