XnView MP 1.8.1
XnView MP 1.8.1
Please, don't post bugs or requests in this topic!
You can download XnView MP 1.8.1 here:
Windows x64 ZIP version SHA256: C4CD674B0489AD9FA40C04F74D5EA57B1638F991E1B9D0A34873D2C9F76FD2BC
Windows x64 SETUP version SHA256: 1DCE64F29631928FC3B60AF4A640EE62935B89088C920589B339C6B9AED19C90
Mac x64 DMG version SHA256: 72B9DF8CF83CC6E59561F4A620587F38FAC5BEA4A946A02AE7D1C7CEED75D6E3
Linux x64 TGZ version SHA256: 5CDE8F365FAAB256E988F72575A71BEE4D30B3F7040BD8DED26EABBA447293A8
Linux x64 DEB version SHA256: CE360910E9199874433C48C1245BBFF65AB09A2F04DB651F10BA31A8B35AF366
ARM version: https://download.xnview.com/XnViewMP-linux-arm.tgz https://download.xnview.com/XnViewMP-li ... _armhf.deb
Linux x64 AppImages version: https://download.xnview.com/XnView_MP.g ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 1.8.1:
3388: [New] Edit XMP - Subject code
3384: [New] LibHeif 1.18.2
3358: [New] LibRAW 0.21.2
3356: [New] Placeholder - Create Date and Modify Date - viewtopic.php?t=45441
3354: [New] MediaInfo 24.06
3352: [New] Experimental video info in thumbnail labels - viewtopic.php?t=46642
3349: [New] No drag in folder view setting - viewtopic.php?t=45990
3344: [New] Viewer info - ExifTool fields - viewtopic.php?t=47809
3277: [New] Import and sort - enumerator for input or output folder - viewtopic.php?t=47294
3342: [New] WebP - lossless metadata editing - viewtopic.php?t=47757
3337: [New] Batch convert - XMP action - viewtopic.php?t=47696
3395: [Bug] Windows - White flash at startup - viewtopic.php?t=47927
3394: [Bug] Viewer - move to - tab remains after last file move - viewtopic.php?t=47893
3393: [Bug] Viewer - move to - ignores first time - viewtopic.php?t=47917
3392: [Bug] cbz cbr not shown in viewer mode - viewtopic.php?t=47864
3391: [Bug] Viewer - set dpi not applied to exif
3390: [Bug] Batch convert - XMP
3389: [Bug] View - Adjust - value too high - viewtopic.php?t=47489
3387: [Bug] Contact Sheet - missing icons - viewtopic.php?t=47888
3386: [Bug] Settings - general - reorder copy combobox - viewtopic.php?t=44093
3385: [Bug] Mac - HIF thumbnails not rotated properly - viewtopic.php?t=47261
3383: [Bug] General - fix ESC closing app in single instance mode - viewtopic.php?t=46341
3382: [Bug] StatusBar - viewer - move position/selection to the right - viewtopic.php?t=47051
3381: [Bug] Pictures deleted in viewing mode still displayed in browser - viewtopic.php?t=44540
3380: [Bug] Viewer - incorrect rendering of image with unequal dpi - viewtopic.php?t=46314
3379: [Bug] Viewer - spotlight - scrolling filelist issues - viewtopic.php?t=46395
3378: [Bug] Browser - search - All fields does not search file dates - viewtopic.php?t=47878
3377: [Bug] Viewer - spotlight - few issues - viewtopic.php?t=47659
3376: [Bug] Up down key to navigate into frames - viewtopic.php?t=47373
3375: [Bug] Batch convert - input - few issues with header - viewtopic.php?t=47402
3374: [Bug] Viewer - info - wrong Info for new image - viewtopic.php?t=47301
3373: [Bug] Browser - banner - few issues - viewtopic.php?t=47276
3372: [Bug] History is purged only when Browser tab is opened - viewtopic.php?t=47042
3371: [Bug] View - transparent index visible when zooming - viewtopic.php?t=47020
3370: [Bug] Show source panels - viewtopic.php?t=46965
3369: [Bug] Viewer - cannot rename file with unrecognized extension - viewtopic.php?t=46952
3368: [Bug] Viewer - crash on quit after deletion - viewtopic.php?t=46832
3367: [Bug] Set as Wallpaper - wrong color profile - viewtopic.php?t=47869
3366: [Bug] Viewer - scrollbars - zoomed image moves left - viewtopic.php?t=47842
3365: [Bug] Compare - A/B mode - does not use bg - viewtopic.php?t=47826
3295: [Bug] Part of the image is obscured - viewtopic.php?t=47492
3364: [Bug] Empty tab - menu items enabled - viewtopic.php?t=47859
3363: [Bug] Curves dialog - viewtopic.php?t=47695
3362: [Bug] Browser - thumbnails - paletted images transparency ignored - viewtopic.php?t=47849
3361: [Bug] Viewer - change color depth - 32bit result when converting 8 to 24 - viewtopic.php?t=47848
3360: [Bug] GPS title - viewtopic.php?t=47835
3359: [Bug] Maximum of view tabs - option not working - viewtopic.php?t=45260
3357: [Bug] Viewer - Panes - viewtopic.php?t=46171
3355: [Bug] Viewer - histogram - background state - viewtopic.php?t=46156
3353: [Bug] Categories panel does not update when category from right click menu - viewtopic.php?t=46173
3351: [Bug] ESC and animation file - viewtopic.php?t=45649
3350: [Bug] Use sharpen and animation file - viewtopic.php?t=46857
3348: [Bug] clipaste argument opens without menu and toolbar - viewtopic.php?t=46029
3347: [Bug] Browser Viewer sync - viewtopic.php?t=47844
3346: [Bug] TIFF JPEG Tile - viewtopic.php?t=47847
3345: [Bug] unicode and exr - viewtopic.php?t=47822
3343: [Bug] PSD - viewtopic.php?t=47804
3341: [Bug] JPEGli - medata warning - viewtopic.php?t=47805
3340: [Bug] Linux - jpeg xl support - viewtopic.php?t=46629
3339: [Bug] Double clicking an image while minimized - viewtopic.php?t=47781
3338: [Bug] Auto crop - viewtopic.php?t=47758
3336: [Bug] Edit XMP - photoshop.DateCreated - viewtopic.php?t=47710
3335: [Bug] JPEG-li subsampling - viewtopic.php?t=47719
3334: [Bug] no audio files plyaing in preview - viewtopic.php?t=47716
3333: [Bug] OS2 bmp format - viewtopic.php?t=47721
3332: [Bug] Fullscreen - toolbar not visible - viewtopic.php?t=47711
3331: [Bug] BMP rgb565 - viewtopic.php?t=47706
3330: [Bug] Find similar - delete file doesnt remove from catalog - viewtopic.php?t=47698
3329: [Bug] IPTC - object name renamed Document title - viewtopic.php?t=47649
3328: [Bug] Windows - context menu in windows explorer - viewtopic.php?t=47541
3327: [Bug] Export preview - add JPEG-LI - viewtopic.php?t=47679
3326: [Bug] Film simulation - presets do not completly saved - viewtopic.php?t=47694
3325: [Bug] Viewer - edit menu - selection commands - viewtopic.php?t=47481
3324: [Bug] Import - add default selection to comboboxes - viewtopic.php?t=47684
3323: [Bug] Browser - filelist - details view - Rating, Color label appearance - viewtopic.php?t=47657
3322: [Bug] Open with - configure programs - show path - viewtopic.php?t=47656
3321: [Bug] Viewer order broken when using search - viewtopic.php?t=47691
3320: [Bug] Capture on command line - viewtopic.php?t=47678
3319: [Bug] Linux - creation date time - viewtopic.php?t=47635
3318: [Bug] Fit window to image causes window to be shifted - viewtopic.php?t=47666
3317: [Bug] JPEGLI greyed image - viewtopic.php?t=47682
Re: XnView MP 1.8.1
The Linux package is 1.8.0, i fix this problem asap
